Showing results forĀ
Search instead forĀ
Did you mean:Ā
adaptive control with pid
Hi, i have pid toolkit 8.6, control design and simulation 8.6 and system identification 8.6, and i working with adaptive control.
i show an example for this, call "simex adaptive control with pid.vi " but i dont find it in the NI Example finder.
i would like  will send me this example.. thanks..
my problem is with an block, i dont find the  block that makes the "adaptive algorithm", and I have doubts about imputs and outputs of block called ARM recursive system identificaciont .
Thanks, and sorry, my english id bad..
Jose Luis Villamil
(5,519 Views)
Please take a look at the link below, because it contains informations about Adaptive Control.
http://zone.ni.com/devzone/cda/tut/p/id/3133
About this example that you want. This is an example that you already find once? Where?
Regards
Luciano Borges
National Instruments Brazil
Luciano Borges
Test Development Engineer
(5,489 Views)
Hi, Thanks for your response. but i dont have this toolkit MFA of cybosoft.
The vi calle Simex adaptive control with pid, in this link. https://www.ni.com/en/shop/labview/improving-pid-controller-performance.html
Thanks and sorry, my english is bad.
Ing. Jose Luis Villamil
(5,479 Views)
See reply here...
http://forums.ni.com/ni/board/message?board.id=170&message.id=353858&jump=true
Barp - Control, Simulation, RTT and HIL - National Instruments
(5,452 Views)
