adc channel id
How can i read an adc channel id when i know that i have four bytes.  The first byte of each block is the channel id and the next 3 bytes are the measurement value. Do i need the string subset? And how does it work?
thanx labviewviewer
Message 1 of 15
(5,005 Views)
Hi labviewviewer,
you can use the string subset function or you work with arrays. To work with arrays, you should first use the string to byte array function.
Mike
Message 2 of 15
(4,998 Views)
Hello Mike,
here is a snippet of my programm.
If you can`t see the picture, then copy it into word.
The string includes the information of my port data.
I used the string to byte data, but don´t know how to split (to get the channel id and the decimal number)
 I ám only able to  use the decimal string to number to change the string.  After the transformation  i get the voltage. But the channel id is missing.
I need the channel id to write it into a file with the voltages.
Like that:
channel 0              1.23
channel 1              2.34
channel 2             1.26
and so on, for all 8 channels
thanx labviewviwer
Message 3 of 15
(4,978 Views)
Hi labviewviewer,
as you said, i can't see the image, but why can't you simply attach it? 😉
Mike
Message 4 of 15
(4,975 Views)
Sorry, i´am new here. How can i sent the pics? With insert/ edit image?
Message 5 of 15
(4,972 Views)
Ok, Mike. Here it is.
Message 6 of 15
(4,969 Views)
Hi labviewviewer,
what are your raw data? Can you show an example string?
Mike
Message 7 of 15
(4,957 Views)
Hello Mike,
Do you remember the Aduc812. I' ve transformed the data from that board from hex into dezimal. So in Labview my raw data from the port consists of a decimal number from 0 to 4095. I can only get the information of the voltage by the formula:  voltage = dezimal * 2,5 / 4096.
The problem is the channel. I' am not able to read the channel number. Only the the data from the port in a while-loop.
thanx labviewviewer
Message 8 of 15
(4,952 Views)
Hi labviewviewer,
yes i remember and i read again your first post. I thought you have a raw value and the result you expect from it.
See this picture.
Hope it helps.
Mike
Message 9 of 15
(4,949 Views)
Hi friends
I am Joseph from London. Anyone tell me the exact meaning of adc.
Joseph
Message 10 of 15
(4,947 Views)
