add 3.0 usb external hard disk to PXIe-8840
Is there a way to add an external 3.0 usb hard disk to my PXIe-8840 controller running LabVIEW RT 2016?
(2,263 Views)
I would expect it to show up an external drive.
Consider the following note: Most real-time targets use letters to indicate different drives. Paths that begin with C are stored on the real-time target’s internal memory. External Compact Flash drives are mapped starting with the first available driver letter after C and external USB hard drives are mapped starting with U.
I recommend checking the following links:
(2,240 Views)
Double-check the disk is formatted to something the RT OS can read (FAT32, ext3) and not something like NTFS or exFAT.
Certified LabVIEW Architect
Unless otherwise stated, all code snippets and examples provided
by me are "as is", and are free to use and modify without attribution.
(2,194 Views)
