add a bitmap in a menu topic
Hi, I would like to use menu functions defined in user32.dll for adding bitmap in the menu bar.
Could you send me an example using either user32.dll or menu activeX.
Thanks.
Alexis de La Fontaine.
Message 1 of 13
(4,280 Views)
Check the example here.
Message 2 of 13
(4,280 Views)
Hi, thanks for response, but i know this example, i would like to use user32.dll.
In this dll, we can find create menu function, add bitmap to a topic, ...
But i don't know how to use this dll.
Thanks.
Message 3 of 13
(4,280 Views)
If you are talking about adding the bitmap to a LV window's menu, then
the user32 function will not work very well as the LV menus are not
windows menus, but rather our own object that draws as a menu and
processes menus as an event.
Greg McKaskle
Message 4 of 13
(4,280 Views)
I create a window menu but i can't receive selected item by user. Is it an event and not a dll? Is it WM_COMMAND ?
Thanks.
Message 5 of 13
(4,280 Views)
You've lost me. The LV menu isn't based upon windows menu objects, and
it will not send notification via WM_ messages. You can independently
use SDK or MFC functions to make a menu object, and you might also be
able to attach this to a LV window, but I suspect that you are dancing
on thin ice. I wouldn't be at all surprised that the child window
containing the menu has problems with drawing and event handling.
Of course, if I'm wrong and you get it working that would be quite cool.
Greg McKaskle
Message 6 of 13
(4,280 Views)
I don't xant to create a labview menu. The reason is that i want to attach bitmap with menu items like Excel, WORD, ...
Here an example which create a menu with user32.dll but i don't know how to receive item selected.
Thanks.
Message 7 of 13
(4,280 Views)
If you drop me a mail, I'll send you a library to use windows (user32) menus
in LV. Benefit of this is that you can have the menus popup everywhere, and
that the menus can have multiple levels (in stead of a menu ring). A menu
can be triggered by everything you want, e.g. a button.
You'll have to modify it to insert bitmaps.
Btw, when a menu item (a user32 menu item, not LV's menu items) is selected,
a message is send to the window. In response to this, a PopupMenus created
and there is a dll function to wait for the selection of the user.
Wiebe.
"secmai" wrote in message
news:506500000008000000C9660000-1031838699000@exchange.ni.com...
bar.
> Thanks.
Message 8 of 13
(4,280 Views)
I'm very interesting by your library for using windows menu (user32) in LV.
Which message is send to the window when a menu item is selected ?
SECMAI
Message 9 of 13
(4,280 Views)
The WM_COMMAND is send to a window if a menu item is selected (NOTE: not
when a labview (LVDChild class) menu item is selected, LV has it's own menu
functions!).
The least significant two bytes of wParam is the identifier of the selected
menu item.
I was wrong about this:
selected,
This is just how I do it! "Normally" (e.g. in C++) windows creates the
entire menu (e.g. with LoadMenu), and sends the messages to the parent
window.
Wiebe.
news:50650000000500000063B50000-1031838699000@
exchange.ni.com...
> in LV.
> Regards,
> SECMAI
Message 10 of 13
(4,280 Views)
