add button which opens another vi
Hi
I have made a vi in which i want to add a button which opens a new vi and ask for necessary input or selectionthen run whole vi.  Also if i won't click its selection button in main vi it should not open it. I have gone through how to make sub vi but couldn't find this kind of option where subvi  can be opened by clicking some button from front panel of main vi insted thet refrence vi symbol is present on block diagram but i need it on front panel. because iam generating exe application for my panel and user can't do necessary setting in subvi with exe file.
Suggest me solution for this.
Thank you
(2,828 Views)
Use a case structure and the "subVI Node setup" Properties.
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(2,783 Views)
