add cursor to the waveform graph
Hi,all,
I want to know how i can add cursors to the waveform graph and display the value,for example,add a cursor to the maximum value point and display the value?
(8,236 Views)
Open the example finder and have a look at "Programmatically Control Cursors.vi".
See how far you get. 🙂
(8,221 Views)
Hi,Altenbach
Thank you for your help.but i cann't find the example.my Labview version is 7.1.
I'm  green.my English isn't good also.you know ,i'm Chinese.i added a attached file and hope it's helpful for you to understand me.
(8,198 Views)
There are examples with 7.1 as well. One is called simply Cursor.vi. For your example, you just need the Array Min & Max function with a property node of the graph. Something like what is shown below. Of course, you have to first right click on the graph and make the cursor legend visible and create two cursors locked to the plot.
Message Edited by Dennis Knutson on 08-09-2008 10:46 PM
(8,191 Views)
Hi,Dennis
Thank you very much!your answer is very helpful.it's exactly what i want.
(8,176 Views)
