add decimal to string value
I need help changing the format of some data that is in a string.  I am reading data from a serial device and want to add a decimal to the data.
Example:
Data read = 2345
Need to display it as 23.45
I tried "Format Value", but can't seem to get it to work.  Is that the right thing to use?  Any help would be appreciated
(3,588 Views)
Are you just scaling by 100? Why not convert the string to a number? Do you need to convert it back to a string?
(3,577 Views)
Just scan and divide by 100.
Of course if you want a string at the end, there are several options, e.g.:
Message Edited by altenbach on 03-23-2007 09:28 AM
(3,573 Views)
Sima and Altenbach,
Thank you for your suggestions.  I was over thinking the solution.  I converted the string to a number, then divided by 100.
Thanks again!!
(3,521 Views)
