add element to cluster indefinitely
Is there anyway to add element to a cluster indefinitely like an array? The number of element of the cluster will depends on the user.
This cluster elements wiill be used as a slider (with multiple elements) later.
I include a VI with several indicators as comparison.
Or anyway to work around this problem?
Message Edited by hito88 on 08-21-2009 05:56 AM
(3,501 Views)
hito88 wrote:
Is there anyway to add element to a cluster indefinitely...
Add indefinately? No.
You could add more than ever possible and then show and hide at run time...
OR
Use an array
OR
Use a picture control (with  the required supporting code that will have to be developed specifically for this app) and make it "looK' like a cluster with an unlimited number of elements.
Ben
(3,486 Views)
I think putting a cluster inside an array would do what you are looking for.
(3,462 Views)
