add hardware config to installer
I have an application running on a number of PCs, when I installed the applications I did a manual install and did not create an installer.
Now I would like to create an installer and include the hardware config in the installer.
Unfortunately I nolonger have the hardware for the project in my PC as it is being used in the target PCs (I am not allowed to buy a set of hardware for my own PC).
I have a copy of an NI configuration export file (.nce) that I saved earlier, how do I include it in my installer.
If I go to hardware configuration in the installer properties, select "include hardware configuration from MAX" and select "configure" Labview allows me to export the current hardware config (which is wrong for the application as I am now working on a different project) but does not allow me to add a previously saved configuration.
Is there anyway of doing this ?.
any help appreciated
Nick
Message 1 of 10
(3,793 Views)
Accepted by topic author Nick_H
Nick,
Export current MAX DAQmx configuration so you have a backup.  Import the .nce from target machine.  Create installer.  Import saved config for current project.
Message 2 of 10
(3,775 Views)
Thanks, that works - I thought I would need the correct harware installed.
Message 3 of 10
(3,768 Views)
I have an application running on a cDAQ-9178. Then I  create an installer. which run the application in others pc without verifying the existence of hardware.
Now I would like to  include the hardware config in the installer.
How can i do that
Message 4 of 10
(3,019 Views)
It seems like the message marked as the solution above would give you the answer you are looking for.  You just need to recreate the installer to include that configuration.
How is your situation different?
Message 5 of 10
(3,007 Views)
I included the hardware installers then I recreated the installer. But when i run my installer it executes without asking for hardware existence😔
Message 6 of 10
(2,988 Views)
You are confusing "hardware config" with "hardware presence".
Hardware existence is something you would have to write yourself.
Former Certified LabVIEW Developer (CLD)
Message 7 of 10
(2,980 Views)
So I am really really confused.
Can you give me some more explanation about this.. how to write it ??
Thank you
Message 8 of 10
(2,976 Views)
You can use the system node to get a list of devices
I am sure there are full examples in the examples folder. (I have not looked to see if there are)
Assuming the array is *not* empty, you can check if the device is present an not just cached.
Message 9 of 10
(2,972 Views)
I will try this one and see.
thank you
Message 10 of 10
(2,933 Views)
