adding 2 signals
Hello All,
I am attaching a code. I want to know how I would add the triangular wave to 24MHz signal.
Much Appreciated
(3,248 Views)
Hi PKBombay,
I'm not exactly sure if I understand your questions. If you would like to simply generate a triangular waveform you can use our Basic Function Generator VI in your Functions Palette under » Signal Processing » Wfm Generation.
If this was not what you were looking for, perhaps you can tell us more about your application.
Message Edited by S_Hong on 11-25-2008 01:51 PM
S_Hong
(3,213 Views)
