adding another syringe + parameters to a drop down menu
Hello All,
I have this code that operates a harvard apparatus syringe pump. It takes the syringe information; does the flow based on that. Now I want to add another syinge with new parameters. How do I pursue with it?
Thank you,
ZA
(3,543 Views)
Without code, we don't know what you need.  The title suggests a Drop Down Menu is wanted somewhere, but where?  Show us the existing code, indicating where you want changes.
BS
(3,524 Views)
Yes, if you could upload your block diagram we can better assist you.
Casey B.
(3,494 Views)
Hi. Thank you for the reply. The problem is resolved.
Zhamak
(3,474 Views)
Great to hear Zhamak.
Could you give a brief overview of what you did to resolve your issue?
So that if anyone else sees this they will know what you did.
-CB
Casey B.
(3,447 Views)
