adding channels to daqmx after Express conversion
Hello everyone,
            I am trying to update a VI I created a couple of years ago.  It was one of my first.  I used the DAQ Express VI.  I received complaints about the computer hanging up every once in a while and thought it might be attributable to the Express.  So I used the LabView function to convert to individual DAQmx tasks.  Everything appears to work okay for the channels that were installed originally.  Now we need to add channels to the readout.  Shot one is of the top level DAQmx icons in the main VI.  The second shot is of the channel setup subVI that the computer created.  In the AI Voltage box you can see the channel I am trying to add, Channel 9.  Am I missing something obvious?  Thanks for the help.
Message 1 of 12
(5,624 Views)
Hi Willy,
don't you think we would be able to give help when we could actually see something in your pictures?
Please attach non-scaled pics (or just the VI!) instead...
So just guessing:
You edited only one of those array constants. As the FOR loop still autoindexes through all the arrays it will stop before reaching your added channel name...
Hint:
You don't need to use SplitSignal when you already get an array of waveforms from your DAQmxRead. Use IndexArray instead!
Message 2 of 12
(5,619 Views)
Hey Gerd
     You lost me on the discussion with the For Loop.  I will start going throught the VI to see if I can figure out what you were talking about.  Until then, here is the VI.  I don't know why I didn't post it to start with but here it is now.
Message 3 of 12
(5,612 Views)
Okay, lets try this one more time.  Here is the VI.
Message 4 of 12
(5,611 Views)
Hi Willy,
set the index display of all array constants before the FOR loop to "9". You will note some of the arrays show grayed elements. Those arrays have less elements then others. As the FOR loop uses autoindexing it will only iterate over the shortest array!
To solve your problem set the missing elements of all arrays.
When you don't know what is meant by "autoindexing" you should definitely go through LabVIEW basics course offered by NI on their website...
Message 5 of 12
(5,607 Views)
I have updated all the arrays that are entering the AI Voltage For Loop.  I have confirmed correct location of wiring, several times.  And I have used NI Measure and Auto to confirm that the CompactDAQ is receiving the proper signal, at least twice.  Still nothing when running this VI.  Is there any setting is the DAQ setup VI that I might have missed?  I am about to the point of erasing all DAQmx icons and start over with an Express VI again.  At least then it worked!  I have even attached the latest and greatest version just in case I accidently clicked somewhere I wasn't supposed too.
Message 6 of 12
(5,581 Views)
Hi Willy,
"TestRig2-0.vi" is missing and so we cannot check any initialization stuff of your DAQ task...
Why do you use a shared variable "task out" when you could use a simple wire instead?
"Still nothing when running this VI."
I don't believe it's doing nothing at all... Either you will get atleast some values from DAQmxRead or it will output an error!
Do you get error messages in the error cluster? If so, which errors do pop up?
Message 7 of 12
(5,570 Views)
Sorry for the delayed response.  When I run this VI under highlight execution, I receive the -200279 error, but it doesn't appear when I run it without the execution.  When I run NI MAX, select channel 17 under Diff Input, I can see the signal I am entering through a Function Generator.  When I run this, I indicate noise.  I have attempted to attach both VI's under this connection.  Let's see if I can figure at least this part out.  Unfortunately, throwing this computer against the wall or into a spinning propeller isn't really an option so let us try to figure this out!  Thank you.
Tim
Message 8 of 12
(5,554 Views)
That error code is due the DAQ buffer filling up before you can read the data.  This is fairly common when using highlight execution with a DAQ.
Message 9 of 12
(5,551 Views)
Yeah, I'm not too worried about that.  It is kind of a pain in the butt when your trying to troubleshoot something, but it appears to work.  I am just trying to figure out why my one channel that I added refuses to showup.  I usually consider myself a pretty decent computer nerd, but this problem is making me feel like its amatuer hour in between my ears.
Message 10 of 12
(5,544 Views)
