adding data to an array
hi need help.. i need to add missing data for the array
YY-Year
MM-Month
DD-Date
mm-minutes
ss-seconds
Data  1YYMMDD mmss0
20.8 1090828 05050
1.2   1090829 10150
7.2   1090901 08400
the above array is the data where i need to insert data for data til 090831
as below
Data  1YYMMDD mmss0
20.8 1090828 05050
1.2   1090829 10150
0      1090830 0
0      1090831 0
7.2   1090901 08400
how to do this? and i need to check for every month is there data missing inbetween? Plz help
(3,295 Views)
Accepted by topic author jeyanthi
Yes.  You will need to iterate through your array.  Index out the current index and the index +1.  Translate the text into dates and use the date functions to determine if a date is missing.  If not, increase the index by 1 and repeat.  If a date is missing, insert a row and set the date to be the last date +1.  Repeat increasing your index which should make it the row you just added.
(3,290 Views)
can i get small example for this..in labview 8.0..plz..thk u
(3,284 Views)
Jeyanthi...
Ravens fan has given you the complete algorith to do the same describing each and individual steps....jusy simply follow it...
Regards
Guru (CLA)
(3,256 Views)
