adding decimal to an integer
I'm reading 3 digit integers back from a controller in the form of XXX. I need to format them to the form XX.X
Example
245 should read 24.5, or 345 should read 34.5.
Besides the easiest method of just dividing bt 10 is there a labview function that will place the decimal in my integer number where I need it to be?
(3,151 Views)
No, division is just fine.Well, you could multiply with 0.1 instead 😄
If it is just a string: insert a dot char after the 2nd char (as most "controllers" managed by VISA functions deliver strings...).
(3,147 Views)
Thank You.....
(3,134 Views)
