adding results of an array to an output
I've already tried looking for a solution but am unable to get it right. do pardon me as i'm quite new to this.
I'm trying to build a VI that randomly generates a whole number for an array of 8 by 8.
and once that is done, to add up the total amount to one numeric indicator.
so far I have this.
http://i35.tinypic.com/35i8u2q.jpg
however it's not working correctly. can someone kindly point me in the correct direction?
much appreciated. 🙂
Message 1 of 10
(3,987 Views)
Please post your image directly to the forum here. Don't give outside links. Use Add Attachments located at the bottom of your composer box.
Mathan
Message 2 of 10
(3,985 Views)
I know it's a little excessive, sorry about that.
Message 3 of 10
(3,980 Views)
Accepted by topic author quarzi
Is this what you are looking for?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 4 of 10
(3,977 Views)
quarzi,
I cant see any image in the link.Just a dot.
Message 5 of 10
(3,975 Views)
Adnan, I'll try out your solution. however, are you able to tell me where I can locate the icons for the summation? I can't seem to find it. I'm using LabVIEW 8.6 Student edition.
edit: found. tryig it out now.
Message Edited by quarzi on 10-06-2009 12:53 AM
Message 6 of 10
(3,971 Views)
I should have labeled that; it's called Add Array Elements and is located in the Programming -> Numeric palette.
Adnan Zafar
Message 7 of 10
(3,967 Views)
Since you said you need whole number, try inserting "Round to Nearest" located in the Programming -> Numeric palette.
Message 8 of 10
(3,956 Views)
Thanks Adnan! It works for me.
Also, thank you all for your replies. 🙂
Message 9 of 10
(3,954 Views)
The above solution is statistically flawed, because 0 and 10 will only appear with 50% of the probablilty of all other numbers. To get equally distributed numbers, you need to multiply with 11 and round to -inf instead.
Message 10 of 10
(3,880 Views)
