adding to prompt string to listbox
hi, i want to create a walk-through script that will prompt a user step by step instructions for a test.
i dont know how to do this, but i had an idea to use listbox and using "prompt" string..
i add my instructions on top of my listbox, but when the area are full, the scrollbar doesnt scroll down. how would i make it go down, or am i doing this wrong?
thanks in advance
Message Edited by krispiekream on 03-12-2008 12:04 PM
Krispiekream
Message 1 of 14
(4,969 Views)
You can change the visible rows by setting the top row. Following property nodes will be needed :
  • Number of Rows : number of visible rows
  • Item Names : use a Array Size function to get the total number of rows
  • Top Row : row number currently at the top
Message 2 of 14
(4,965 Views)
my idea is to use the listbox to only list my instructions...
as a user complete an instructions, he/she will click OKAY..
when all the instructions is filled. the test is completed...
my idea is to use the listbox just for display...
i hope this image will help
Message Edited by krispiekream on 03-12-2008 12:33 PM
Krispiekream
Message 3 of 14
(4,963 Views)
I just want to clarify something. Do you want to use the listbox to display (in order) each of the resposes that the user enters in the dialog box sub VI?
Eli S.
Message 4 of 14
(4,927 Views)
yes, thats correct
Krispiekream
Message 5 of 14
(4,912 Views)
Hi krispiekr...
I have created a simple example that illustrates how you can do this. I have saved it for LV 8.5 and I am also attaching a screenshot.
Eli S.
Message 6 of 14
(4,895 Views)
cool, thanks, you are the best
Krispiekream
Message 7 of 14
(4,878 Views)
i finally got a chance to take a look at this again,
can someone save the listbox.vi into labview version 7.0 please?
thanks in advance
Krispiekream
Message 8 of 14
(4,820 Views)
Here you go!
Eli S.
Message 9 of 14
(4,783 Views)
i tried adding a text into a listbox,
but i am having errors?
Krispiekream
Message 10 of 14
(4,761 Views)
