adding values to a variable/array after each cycle
I have attached a sample VI in this message.
I have a FOR loop.  If I use a numeric say 5, for each cycle, I would like to multiply 5 to each cycle count and I want to have the products of all the cycles added up in real time and store it in a variable/array.
for example:
cycle count     product      current sum
0                       5x0               0
1                       5x1               5
2                       5x2              10+5 = 15
3                       5x3              15+15 = 30
and so on.
And I have to apologize for pressing the wrong button on the keyboard and I submitted the post before I even finished writing.
Message Edited by qiora on 10-03-2005 10:42 AM
(2,943 Views)
Very close.  You also need a shift register to save the most recent value to the next iteration of each loop and add them together...
See example attached
(2,931 Views)
Thanks for the reply.  I am using LabView 6.1 here.  Can you do a printscreen and let me take a look at what you have that way?  Thanks.
(2,928 Views)
Here's something in v6.1
Fading out. " ... J. Arthur Rank on gong."
(2,913 Views)
