address
I have a vme-mxi-2.I must test my pcb with this instrument.I insert the vme-mxi-2 in solt 0,and pcba in solt 1.the base address of pcba is 3800H in the document of pcba testing.and the error register is in 3800+4H.how I can use visa in labview to access the register.Here is my program.but It can not access the address.
(2,765 Views)
Thank you for contacting National Instruments support. It looks to me like your program should work with one minor change. The offset input into your VISA In 8 VI currently has a value of 3804. I believe VISA will go out and find the base address for you, so try putting a value of 4 for the offset input instead of 3804.
I hope this helps! Let me know if there is anything else I can help with or clarify. Have a great day!
Doug K.
Application Engineering
(2,765 Views)
