adjust control values while VI is running
Have another question, but its irrelevant to my other post so I thought i'd make a new one:
I'm near complete with this VI, however i would like to add the ability to change my Control values in my front panel while the VI is running, either through some sort of feedback or w/e.  For example, if the power supply i'm running is at 10V during the time, i would like to bump it up to 20 v without having to start/stop the VI completely.
Is there an efficient/good way to do this?
(2,285 Views)
Really not able to open your attached vi as most of its dependencies are not included. So without looking at it I would say that putting everything in an event structure, then having events trigger on changes to your controls would be the way to go. But without seeing the code ...
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,272 Views)
