adjust the space between text when printing
Make sure that the Visible area only option is set to True and that your fields are populated.  It works fine on my computer.  Because you are using the "Visible Area Only Option" you dont need to use the margin or layout config functions, you just have to move the move the text to a different part of the screen.  I took all the layout and margin config functions because they seemed to interfere with the operation.
Message 21 of 21
(416 Views)
