adjusting serial communication baud rate
-1073807343 Definition:
Warning -1073807343 occurred at an unidentified location
Possible reason(s):
VISA:  (Hex 0xBFFF0011) Insufficient location information or the device or resource is not present in the system.
I don't understand why you are terminating WCESCOMM.EXE to work around this warning.  Can you explain?
JLV
Message 11 of 14
(1,057 Views)
Here's the scoop...It works if you terminate the process, it fails if you don't.   Until I discovered this, I was unable to test/debug the application on the PC.  Not very productive.
I now have a working application on the PDA, which was the ultimate goal.  If you have another work around, I would be happy to consider it.
Message 12 of 14
(1,051 Views)
HI,
i am also getting the same. can you tell me other ways to communicate with 57600Buard rate for PDA.
Regards
ELLAPPAN P
Message 13 of 14
(743 Views)
If you get that same error then use task manager to kill the WCESCOMM.EXE process.   It is used with ActiveSync and if it is present as an active task on the PC (ie - its running), then you will get the error message and can't go above 9600.   Kill the process and everything will be fine.
Message 14 of 14
(713 Views)
