ado tool variant to string array
Hi
im working with the ADO tool. When in execute a query i get a variant output. But i like to have a string array output. I modified the Ado subvis, but the problem is that when i readout the string array the last cloumn is empty. Does someone knows howto conbvert the variant output to a string array?
thnx
Labview CLD , Engineer/Manager
Promedes and DSM
using LV 7.1, 8.0, 8.2, 8.5 and 2009 SP1
http://www.promedes.nl
(4,116 Views)
If you mean the DB toolkit, then it outputs a 2D array of variant. You need to wire it into 2 nested auto-indexed for loops and convert it inside.
___________________
Try to take over the world!
(4,111 Views)
thnx, i just solved the problem myself 😉 you can just use the variant to data and wire a 2d string array tot the type..
Promedes and DSM
(4,109 Views)
Interesting.
At least in LV 7.0, you can only do that with the Variant to Data primitive and not with the DB Variant to Data primitive.
Must have been what threw me off.
___________________
(4,103 Views)
