advanced signal processing toolkit for labview 2011 64 bits
Hi all,
I am looking for a version of advaced signal processing to work with labview 2011 64 bits and I can't find anything. Is it possible to work with labview 2011 64 bits with this toolkit?
Thanks in advance.
Juan Luis
Message 1 of 8
(3,502 Views)
Juan Luis
At the moment, most toolkits and modules of LabVIEW are only presented in 32-bit versions. However, you can easily install those toolkits and module on a 64-bit OSs and they work as you would expect. You just need to install the 32-bit version of LabVIEW before installing the software.
See more information in here:
https://www.ni.com/en/support/documentation/supplemental/18/labview-32-bit-vs--64-bit-applications-f...
Hope this helps.
Barp - Control, Simulation, RTT and HIL - National Instruments
Message 2 of 8
(3,473 Views)
Thanks for the answer, but ,How can I use the 8 GB of RAM that my laptop has? with the 32 bits version of labview it is not possible. Isn't it?
Many thanks
Message 3 of 8
(3,464 Views)
Yeah. if you would need 64-bit OS for that. Can you describe your application? Or which function are you interested using in ASPT ? Maybe we could find workaround for you.
Message 4 of 8
(3,454 Views)
LabVIEW 2011 (64-bit) Advanced Signal Processing Toolkit has been released on April 17, 2011.
Mikhail
RF Toolkits, Product Support Engineer
Message 5 of 8
(3,378 Views)
Mikhail:
I think you intended to state April 17, 2012 as the release date.
-AK2DM
Message 6 of 8
(3,372 Views)
Yes, you are correct. Thanks for pointing that out.
Mikhail
Message 7 of 8
(3,370 Views)
Thank you very much
Message 8 of 8
(3,359 Views)
