advantech 4702 waveform display has no video effect
hi, everybody
i have a silly problem i an using ADVANTECH usb4702 for waveform display in my labview, the sampling rate is 1k, & a default buffer also 1k.
now the problem is the waveform chart output  is not satisfactory in the sense that even if i set the update mode of the chart in "stripchart " mode,continuous  transition (video like) effect is not there. What i am getting is a
static waveform then a gap then after a few moment again a trail of static waveform.... like this way,
now i am not familier with advantech as i have allways used ni-usb6008(i get the video effect easily their) ,
can anybody help me , how to make the video effect (unfortunately i have to use advantech card)
Message 1 of 1
(2,431 Views)
