advantech
I am Davide Masi,
I am a Labview developer at EGICON srl, Mirandola (MO), Italy.
I'm working with the version of Labview 2009 on OS win7.
I need to interface Labview2009 with two modules Advantech 4711A and 4751L.
  1. Is possible to have two simple examples of read / write for Labview, on modules 4711A and 4751L?
  2. I have the old VI Labview to read/write modules that run on winXP. This VI link to the library AdvLvdaq.dll. This examples on Labview2009 and Win7 not run. The library AdvLvdaq.dll on win7 and Labview2009 can not find it.  The library is changed? What could be the problem? I try to reinstall LabVIEW?
Best Regards
Davide
(3,996 Views)
HI,
I suggest you check that you have correctly installed the driver for your device besides the drivers compatible with LV. Unfortunately, I can not give more information or example, because the device is not a National Instruments products.
Sabrina
(3,930 Views)
