after close my exe,crash occured 0xc0000005
KEY_VALUES_STRING: 1
    Key  : AV.Fault
    Value: Read
    Key  : Analysis.CPU.mSec
    Value: 10531
    Key  : Analysis.Elapsed.mSec
    Value: 255651
    Key  : Analysis.IO.Other.Mb
    Value: 31
    Key  : Analysis.IO.Read.Mb
    Value: 15
    Key  : Analysis.IO.Write.Mb
    Value: 95
    Key  : Analysis.Init.CPU.mSec
    Value: 2390
    Key  : Analysis.Init.Elapsed.mSec
    Value: 105983
    Key  : Analysis.Memory.CommitPeak.Mb
    Value: 193
    Key  : CLR.BuiltBy
    Value: NET48REL1LAST_C
    Key  : CLR.Engine
    Value: CLR
    Key  : CLR.MissingMetaData
    Value: clr!g_pConfig
    Key  : CLR.Version
    Value: 4.8.4515.0
    Key  : Failure.Bucket
    Value: NULL_INSTRUCTION_PTR_INJECTED_CRASH_c0000005_lvrt.dll!Unknown
    Key  : Failure.Hash
    Value: {22c98b3c-6c00-0716-970b-eac6365079a7}
    Key  : Timeline.Process.Start.DeltaSec
    Value: 403
    Key  : WER.Process.Version
    Value: 1.0.0.32
dmp file is attached
please help me, any help are appreciate
Message 1 of 13
(1,111 Views)
Are you making dll call in your VIs?
George Zou
Message 2 of 13
(1,102 Views)
Just to expand a bit on this, some instrument drivers make calls to dlls.
Bill
CLD
(Mid-Level minion.)
Message 3 of 13
(1,078 Views)
If I'm interpreting the dump correctly it looks like it's trying to execute the function at 0x0 which would be an issue. Without the PDBs you can just tell that the functions before that are from lvrt so not sure there's much information to be gained from just looking at the dumps.
Even if you had the appropriate symbols there's a good chance there isn't enough information in the dump itself.
Message 4 of 13
(1,060 Views)
yes,ZLG-CAN uses DLL
it has CAN:ZLG(周立功),RT,PLC
Message 5 of 13
(1,042 Views)
You need to check dll calls to make sure NO null pointer pass to them.
George Zou
Message 6 of 13
(1,038 Views)
I will reduce the drivers one by one to see which driver reports the error
Message 7 of 13
(1,038 Views)
its ZLG-CAN(周立功),after i remove ZLG,crash not occured
Message 8 of 13
(1,033 Views)
There are a number of possible culprits.
The most likely is that whoever wrote the VIs that call the DLL functions made one or more errors in configuring the Call Library Node or is not handling data buffers or data types correctly.
The second is a bug in the DLL.
The third is a bug in LabVIEW.
Depending on the C experience of whoever wrote that LabVIEW wrapper, chances for the problem to be in there is anywhere from 50% to 99% with the reminder being almost completely a bug in the DLL. While bugs in LabVIEW do exist it is in the field of using the Call Library Node extremely rare in comparison to the other two reason!
Rolf Kalbermatter  My Blog
Message 9 of 13
(989 Views)
ZLG-CAN driver and its wrapper VIs are widely used.  It's unlikely the culprit.
@Yuanxj
There are many post about ZLG-CAN driver.  See if you can find some examples.
George Zou
Message 10 of 13
(973 Views)
