after quitting cpu runs at 100%
If i close the project after 4) (and the cpu is being eaten), then the whole LabView process stops, as if i killed it from task manager.
Every other vi works fine.
Sorry i cannot send the vi, because of legal issues (company work).
The problem appears when i call my dll from an almost empty vi, too. But as i said, not always.
Well, let me tell what exactly my vi and dll do:
The application displays and processes data received from CAN bus via a CAN-USB transceiver.
- My vi first calls a function from the dll (init), that creates a thread listening to some events (new message received on USB).
- Then in my vi i have an EventCaseStructure, that is listening a user event, created by me (and passed to the dll), if the dll gets an interrupt, it passes the data to LabView with PostLVUserEvent library function, and then my vi recognizes it as a user event.
- When i want to quit the vi, first i call the dll's Stop() function, that terminates the thread and frees up everything, then i destroy my user event, and finally close my vi.
So this is the situation.
Message 11 of 15
(964 Views)
Does the Stop() work always correctly in your DLL?
Do you have any loop after that in your VI which could run at 100% load (untimed loop)?
Your first sentence creates the impression that LabVIEW crashes when closing the project after step 4). Is that correct?
Do you get any "investigate errors" messages when restarting LV?
Norbert
Norbert
Expert: Geometry
Message 12 of 15
(962 Views)
"Does the Stop() work always correctly in your DLL?"
i use trace messages and debugview, and it seems to be all right (there is a chance, that im wrong)
"Do you have any loop after that in your VI which could run at 100% load (untimed loop)?"
no, nothing. no untimed loops, and timeouts everywhere.
"Your first sentence creates the impression that LabVIEW crashes when closing the project after step 4). Is that correct?"
that's right.
"Do you get any "investigate errors" messages when restarting LV?"
no, it just offers to recover the project becouse "it did not shut down normally".
Message 13 of 15
(960 Views)
Any advancements on your CPU load problem?
I have the same problem sometimes: After stopping the program the project still uses one core (25% in my case). (LabVIEW 2014 32bit)
Message 14 of 15
(714 Views)
The OP hasn't been here in almost eight years.  You probably should start your own thread.
Bill
CLD
(Mid-Level minion.)
Message 15 of 15
(710 Views)
