after writing an html report on a floppy disk and removing it, labview shows an error message window: disk not present
after writing an html report on a floppy disk and removing it, labview shows an error message window: disk not present.
My pc is based on asus motherboard. Labview 7 and Windows 2000 sp4 installed.
The error message continue also if i stop the application that generated report on a: .
I've got this problem only on a pc: on other machines i don't have this problem (Labview only continues to access floppy but it doesn't show any window).
Find below an example: first press the button to create a report on a: then remove the floppy, after 30-35 sec i've got the error message
(2,813 Views)
I tried your vi: I don't get any error message after removing the disk but LV7 keeps on accessing the drive at regular intervals even if you stop the vi and close it!!! This is not supposed to happen.
The only way to stop it is exit LV7.
If you don't use the file dialog and you wire a full path, you don't get any problem.
I also created a very simple vi that conditionally writes a text file on a: and I got the same behaviour.
This problem occurs only with LV7, I tried the same examples in LV6.1 and everything was fine.
If anybody wants to try I attach this simple example,
Alberto
(2,813 Views)
I saw the problem on my machine and created a formal report for R&D.
Jeremy Braden
NI
(2,813 Views)
