agilent 33220a labview 7.1 driver
I want to ask LabVIEW 7.1 driver for Agilent 33220A. I installed 7.0 and as a result it doesnt work.
Can somebody help me about this matter
Thanks a lot
(4,492 Views)
There is no 7.1 version of the driver. Even if there were, it would be no different than the version you downloaded. Simply saying it doesn't work is not enough information to help at all. You need to provide details such as error codes you get, the connection type, etc.
(4,486 Views)
thank you very much for your quick answer,
After  I installed driver to the int.library, the blocks of the driver doesnt seen as seen in the attached.
(4,480 Views)
I don't see the same thing when I place the ag33xxx folder in the instr.lib folder and restart LabVIEW. My guess is that either you didn't restart LabVIEW or you put the folder in the wrong place. In any case, you can still browse to the llb and use the functions or if you want, you can use the Tools>Advanced>Edit Palette Views to repair the menu.
(4,477 Views)
Thank you very much for your help 🙂
Best Regards
Ayse
(4,467 Views)
