agilent 34401A,gpib-usb-b,and labview
 I am beginner to labview
Trying to control Agilent 34401A connected through GPIB-USB-B using Labview8.6
I want to read DC currency from agilent ...
 If someone has a code for that or something else pls send it to me...
 thanks
Message 1 of 8
(6,727 Views)
Should be everything you need.
http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=978
Message 2 of 8
(6,713 Views)
Don't even have to download it unless you want to make sure you have the latest. The 34401 driver has shipped with LabVIEW for as long as I can remember. Look on the Instrument I/O>Instrument Drivers palette. For an example, open the Example Finder.
Message 3 of 8
(6,708 Views)
this link is now dead, can you please forward a new link please!!! I also need this code!
Thanks!!
Message 4 of 8
(4,356 Views)
The drivers that shipped with LabVIEW aren't doing it for you?
Bill
CLD
(Mid-Level minion.)
Message 5 of 8
(4,349 Views)
Obviously someone who hasn't actually read the thread.
Message 6 of 8
(4,335 Views)
sorry guys, figured it out, apparently labview has the VISA Vis and GPIB Vis built in so all you have to do is drop and place and populate the i/o of the vi's.... its so misleading when instrument manufacturers give you different languages to use, and the interface module recommends using VISA. got me all confused, but the drivers indeed through NI do work for non-NI equipment!! Thank you!!!
Message 7 of 8
(4,302 Views)
Why would you be using the VISA and GPIB functions? Use the complete instrument driver for it.
Message 8 of 8
(4,293 Views)
