agilent 4395a impedance analyzer
This picture shows a query  - in this case, a request to send the ID of this instrument.  The VISA instrument control is a dropdown menu where all your VISA instruments recognized by NI-MAX are.  The error out of the VISA write is wired to the error in of the VISA read, meaning the write will happen before the read.  Some commands just tell the instrument to do something so you don't need the VISA read.  (In the real world, some commands take a long time to process and you may need additional code to take this into account, but let's stick with the basics.)
If you know how to do your measurement manually, you should be able to pick out the commands needed to do the measurement, then you should be able to string them together.  Given that you have some exposure to LabVIEW, I hope a lightbulb goes on and you can start programming.  Maybe you can eventually build your OWN library of CUSTOM drivers!  😄
Don't be afraid to ask for help!
Bill
CLD
(Mid-Level minion.)
Message 11 of 46
(4,391 Views)
If you place the three VIs on the block diagram and wire the error out to the error in in squence, you can 'right-click' on the inputs of the first two and select 'create control'.  On the front panel you should have the controls select the mode and channel, along with one for wether to query the ID and one to reset the device during intialization.
hp4395a Initialize.vi
hp4395a Instrument mode/chan select.vi
hp4395a Close.vi
The block diagram should look something like this:
You are right about the plug and play version, it is very difficult to understand.
Message 12 of 46
(4,389 Views)
Hi Jack47,
I have tried to reproduce the block diagram you sent but I have the following error message that I do not understand: Could you please help me?
Thank you very much for your previous message!
Message 13 of 46
(4,345 Views)
Do you have the IVI Compliance Package installed?
Message 14 of 46
(4,340 Views)
I do not think so. Because in the IVI folder, I only have one file of configuration settings. Could please tell which packages I have to install? Thank you.
Message 15 of 46
(4,333 Views)
What's wrong with clicking on the link I gave you?
You should also not have to guess whether you installed something or not. If you don't remember, open MAX and expand the software listing. If you installed it, the compliance package will be listed.
I have no idea wha you mean by IVI folder and configuration settings.
Message 16 of 46
(4,328 Views)
No I do not have it installed I am going to install it! It is not in the MAX configuration.
Message 17 of 46
(4,322 Views)
Hi, I am using this driver right now, but the VIs are broken due to some dll issue. I guess some additional installer should be installed for this to work fine. As the driver is developed a long before, the developer is not sure of what installer he used. So, pls can you help me with this.?
Note : these VIs are working fine in 32 bit OS but not in 64bit.. Y is this so? Can I overcome this.?
Thanks in advance
Message 18 of 46
(3,480 Views)
Either get a 64-bit version of the dll or use the LabVIEW driver. The project style driver does not use a dll.
Message 19 of 46
(3,475 Views)
I searched for the 64 bit dll for the same but couldnt find till now. If any of you guys knows about it, please send me the link.
Message 20 of 46
(3,473 Views)
