agilent 8114a
Looking for instrument driver for Agilent 8114A Pulse Generator
(3,455 Views)
I have an LV 4 driver for an HP 8116 function generator. If you think it might be of some use as a starting point, let me know. I opened it in LV 6.0.2 and it had some errors, which I did not examine. However, this indicates that the conversion might not be straightforward. From the style it appears that it was written by HP(Agilent) or NI, not me.
Lynn
(3,456 Views)
The best place to look for instrument drivers to use with National Instruments' products is www.ni.com/idnet. There are currently drviers for more than 3,000 instruments and counting. If you are unable to find the specific driver that you would like, you may request it and see if there's any possibility of one being created. If you have a driver that is not available on the instrument drvier network, you can also submit a driver for review.
Jared A.
(3,455 Views)
Hi Lynn,
I am looking for a driver and I think you have it. Could you send me a copy of Agilent 8114A Pulse Gen Driver in LV4.0 or above. Thanks.
Iqbal
(3,247 Views)
