agilent e444x esa screen capture (trace with marker) to front panel/graphics file
Hi all,
Thanks to Dennis Knutson and the ni.com documentation staff, I was able to find out how to export a waveform trace from my Agilent E4445 ESA to a graphics file.  The issue I am having now has to do with markers.  When I do a peak search, the marker will appear on the ESA screen, but it will not appear on the waveform trace sent to the front panel or in a graphics file.  Does anyone know of a VI out there that will take care of this?
Thanks in advance,
Nina
(2,621 Views)
this is due to the drivers issue
re installling lab view has fixed this issue
AB
Kudos are Accepted
(2,580 Views)
sorry wrongly posted
AB
Kudos are Accepted
(2,573 Views)
Hello Nina,
I believe you should be able to capture the amplitude and X position of your marker on your agilent e444x device via a vi called "query marker", which can be found in your agilent_esa_psa_series plug and play drivers (http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1890). The location of the query marker vi in the plug-and-play directory is Aglient_ESA_PSA_series->Public->Data->Query Marker.vi.
Best,
Blayne Kettlewell
(2,557 Views)
