agilent signal generator and labview code
Hi all
I have Agilent 33220A Signal Generator.I want to generate square signal and convert this signal to a graph in labview with proper code but i dont know how to do.Please help i have limited time
Regards
(3,404 Views)
You'll need some sort of instrument connected to its output that can capture the signal. A DAQ card or oscilloscope would be appropriate. What do you have?
(3,393 Views)
Yes i have all these.From agilent ouput one connector goes to DAQ other goes to oscilloscope.I am stuck in labview code
(3,386 Views)
Then explain in detail where you are stuck. There are numerous examples for both DAQ and scopes. You only need one to capture the signal so pick one. If you choose the scope, provide make and model. If it had a driver, the basic example that comes with it should be most of what you need.
(3,381 Views)
@sgirgin wrote:
Hi all
Regards
Limited time on your part is not our problem.
Learning how to program in LabVIEW isn't something that can be done overnight.
(3,372 Views)
