agilent
Hello everybody,
I would like to use my waveform generator Agilent 33500B with Labview. But the problem is that I can not find one driver for my generator. I just found one driver for the 33220A .
Do you know where I can one driver for my generator?
Vitroze 🙂
Message 1 of 12
(6,854 Views)
Message 2 of 12
(6,851 Views)
Message 3 of 12
(6,846 Views)
Exactly the instruments I mentioned. I don't want to be rude, but you need to read a bit better.
Message 4 of 12
(6,820 Views)
Yes,   I agree with what you said. It's just in your list, my generator is not mentionned.
I said that because with labview, I downloaded one driver with "search  driver" and it download one driver for 33522A and it didn't work.
I going to try with your link and see if it works.
Thank you 😉
Message 5 of 12
(6,795 Views)
What is the exact model number? What exactly do you mean by doesn't work. Details such as error numbers and message, please.
Message 6 of 12
(6,785 Views)
My model is 33500B.
When I click on the button run, my soft doesn't communic with my generator
Message 7 of 12
(6,778 Views)
According to that list from agilent, there is no such model.
I don't know what VI you are talking about and you have not provided the error code or message. What is your physical connection?
Message 8 of 12
(6,773 Views)
I used usb connection, that is my first step.
After I would like to usb GPIB connection.
Message 9 of 12
(6,769 Views)
Accepted by topic author vitroze
Your first step its to verify that the instrument appears in MAX. You may have to install the agilent I/O library.
Message 10 of 12
(6,739 Views)
