ajax and https
I have a thin client based on the code given here https://decibel.ni.com/content/docs/DOC-15361, it is working fine however does anybody know what is involved to get this working with https? I have limited programming experience so if anybody knows any quick fixes I would love to hear from them. I have also tried it in non IE browsers and it does not work even though from the code it appears it should.
Brunswick
(3,049 Views)
Google SSL
(3,045 Views)
Hi Brunswick,
I'd recommend asking your question as a reply to the Community post that you linked and based your own coding on. This question will then be see by the developers of that example, so they may be likely to help you.
Kind regards,
Tori
Student
(3,026 Views)
Thanks very much Tori M I will do that.
Brunswick
(3,019 Views)
