al acquire waveform
Hi~
I had have used the Al Acquire Waveforms in Labview 5.1 long time ago.
Recently, I try to use Labview 8.6 but I couldn't find the  Al Acquire Waveforms.
So, I want to know which icon can be used instead of  the Al Acquire Waveforms.
Thank you for your time^^
(3,838 Views)
Have you installed the NI DAQ?
see here
(3,836 Views)
NI DAQ is DAQMAX???
If it is, I already installed ^^
(3,826 Views)
No, it is not DAQmx and no you did not install it. The functions you are looking for are in the traditional DAQ driver. The link above is not at all appropriate. Look here from a couple of days ago. The exact same question gets asked extremely often.
You should be thinking about converting to DAQmx, though.
Message Edited by Dennis Knutson on 05-21-2009 05:45 AM
(3,822 Views)
If you are using an old Daq board you can not use any NI-daq version. You have to find out which NI-daq who is compatible with your board.
Also see here http://digital.ni.com/public.nsf/allkb/F185E098C7EC5A3486256D2E00691BB2
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,805 Views)
