alarm & Event query.vi
I`ve problems useing the alarm & event query.vi with LabVIEW7.1.  The table or multicolumn listbox output from this vi only gives very old alarms. It is possibe to read any ErrorTag and the alarm and logging data in the .scf file is enabled.
If I use an alarm an event view on Citadel 5 Universe it shows the same old alarms.
Is the Citadel Database corrupt because of changing error Tags in the Database or because of changing PC-name.
I`m very thankfull whith any help !
Message 1 of 13
(4,332 Views)
did it work correctly before?
It may be that you are experiencing that because of a computer name change. Please see the following document:
How to View Alarms and Events with Citadel 5
http://digital.ni.com/public.nsf/allkb/40D4B55AE102D53E86256DD80073996D?OpenDocument
Let me know if it helps.
Message 2 of 13
(4,298 Views)
I think so. I remember from my earlier DSC project that not only changing PC-name renders the Citadel DB useless/corrupt, but transferring it from PC to PC in N/W by simple copy-paste operation also renders it corrupt.
There is something done by NI internally to make it hooked it to the PC/Host name.
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 13
(4,293 Views)
I encountered this problem in LV-LV DSC 8.5 & 8.6.
Message 4 of 13
(4,292 Views)
Hi again,
it seems I sent the wrong link...here is the one I meant:
Why is My Citadel Database Missing After Renaming My Computer?
http://digital.ni.com/public.nsf/allkb/F3DE0C156BFD12EF86256D2B00748475?OpenDocument
Message 5 of 13
(4,290 Views)
I think the only way to restore the Citadel DB is to edit the Windows Registry, but it will require Admin priveleges, which may not be available for developers in most of the companies.
Message 6 of 13
(4,287 Views)
Aah! Joseph has already sent the correct link.
Message 7 of 13
(4,286 Views)
Thanks to Josepf and Partha, Next week I`ve the possibility to work on this machine. I will let you know if I was able to solve it.
marting74
Message 8 of 13
(4,258 Views)
Will be waiting for that... Smiley Happy
Message 9 of 13
(4,254 Views)
I first tried to compact the corrupt Database with the MAX and get the Errormeassage "x unspecified error". The I created a new Database and set the Database Path for Historical & Event logging with the Tag configuration editor to the Database path. The new Database can be compacted without an error meassage with MAX and the Historical logging is also ok but when I call the Alarm&Event Query.vi I get the error. I`m using LabVIEW7.1. DSC.
Fehler -1967386611 ist bei HIST_RunAlarmQuery.vi,  aufgetreten.
When I set the Database Path back to the original corrupt Database this error window is not activated.
How can I go on
Message 10 of 13
(4,221 Views)
