align and resample doesn't output all waveform data?
When I use align and resample on a waveform (which should show two data inputs at this stage but will have 6 eventually), it only outputs the first one. Is this something to do with the dyanmic data type? My VI is attached.
I've been working on this VI with johnsold at this link: http://forums.ni.com/ni/board/message?board.id=170&message.id=401352&jump=true#M401352  and he had suggested that I use a different strategy for the downsampling which I have also tried to implement but I'm not having success with that either.
If someone can help me with either of these, that would be great.
Claire.
(3,072 Views)
Claire,
Try taking out the To DDT VI.  When I did a simple test with it in place the data no longer lined up.  Instead, just wire your array of waveforms straight into the signals input and it should work a lot better.
ColeR
Field Engineer
(3,047 Views)
