align indicator value to right
how can I set on default the alignement of indicator values to right?
this should be possible I guess.
And how can I set on default my changes on numeric properties?
yves
(5,935 Views)
Just select the text in it and press CTRL+0, you get a window to format the text of the indicator, or there is a combo~box indicating the selected font, you can also use this.
I'm not sure what you mean by the second question, but in tools...options, there are a lot of configurations you can do.
If you don't find what you need, please clarify your question, someone will help you.
Paulo
(5,930 Views)
Thanks. But don't want to align the label. I want to align the value in the field.
I'm using LabView 7.1.
For the numeric properties: I want to have set the default for the digits of precision on "2" for example.
Yves
(5,927 Views)
That was what I was mentionning, select the value and do the things I told you on the last e-mail.
Regards
(5,925 Views)
Sorry, but I'm to stupid for that. I select "numeric indicator" on the front panel. then I select the "0" and press "CTRL+0". in the pop-up window I set the alignement to right and check "panel default". then I place another "numeric indicator" and the "0" is aligned on the left again.
Yves
(5,921 Views)
If you want to make it default, the best thing to do is create your own control.
Right click on the control, select advanced...customize, here you can do what you want to your indicator/control, also the precision...
For changing the precision by default (and other default options) I found something thet might be helpfull:
http://labview.brianrenken.com/INI/undoc.shtm
Hope it helps...
Paulo
(5,919 Views)
正解,谢谢Cat LOL
(5,374 Views)
