alpha numeric keyboard
Hey everyone
I am trying making alpha-numeric keyboard which is integrated with hard keyboard of my PC.I am having a very basic knowledge of labview,using that i trying making it but now i'm facing problem, when i press shift key ..it give me fluctuation problem. Here i'm using user event for shift key value generation but as i pressed shift ,two event works together one is "key down event" and another one is my user event. i don't know how solve this ...It would be greatful if anyone help me with this. I'm attaching my vi below
(3,480 Views)
Hi sky,
please clean up your VI at first!
Most of those case structures are pure Rube-Goldberg!
Way too many property nodes, mostly used to replace local variables!
(3,462 Views)
Thanks for your reply, I definitely look into it but what is the solution for proper working of shift key.
(3,393 Views)
You are misunderstanding Gerd's post.
He is telling you he can't give you a solution because the VI is so messed in the basics of LabVIEW style and good programming practices, he can't tell what is going wrong in the actual functioning of the VI yet.  Heck, you may even stumble across the problem yourself in the process of cleaning it up!
(3,362 Views)
