alphabets to numbers
hi
i want to assing values to alphabets from A to Z as 0-15. like a=0 ,b=1 and so on ,
so that vn ever i give any word string like BALL it is converted to 101212 which is numeric
so plz if sme1 can help me out i am new to Labview
maak
Message 1 of 22
(4,385 Views)
The "String to Byte Array" function might more or less be what you're looking for. It converts a string to an array of U8 codes (ASCII codes). You can convert the string to lower/upper case before or subtract an offset from the result to better meet your needs.
http://zone.ni.com/reference/en-XX/help/371361D-01/glang/string_to_byte_array/
Message Edited by dan_u on 10-07-2008 11:09 PM
Message 2 of 22
(4,375 Views)
You can try something along these lines here:
Message Edited by jmcbee on 10-07-2008 03:18 PM
Message 3 of 22
(4,371 Views)
maak,
Why not just use ASCII characters which are industry standard?  See here for a table of ASCII characters.  http://digital.ni.com/public.nsf/allkb/47CFD9C7682DCB2A86256FF800781EB7
Wow! Talk about being late for dinner.
Message Edited by centerbolt on 10-07-2008 05:14 PM
Message 4 of 22
(4,369 Views)
SIR
i want to assign the fixed values from 0-25 to alphabets so wat ever is the input string it converts it to numbers as A to 0 b to 1 and if i write the sentence it convert it all in to number as the given values
thnx
Message 5 of 22
(4,343 Views)
This will not be very useful, because you cannot reverse the operation. 101111 could be BALL, JLL, BABBBB, JBBL, or many other variations. What is the purpose of this operation? Does it need to be reversible, or are you just trying to create a hash or similar?
It might make more sense to use 2 digits for each number, e.g. BALL=01001111. Please explain what you need.
Message Edited by altenbach on 10-07-2008 02:29 PM
Message 6 of 22
(4,338 Views)
I must be misunderstanding you, the examples I provided will take a string, say "BALL", and convert that string to an output of 101111.  Is this what you are looking for?
Message 7 of 22
(4,337 Views)
You've gotten enough information to write the code but I would also suggest that you might want to use the Format Into String instead of the Number to Decimal String. The Format Into String allows you to set a fixed width and pad with zeroes. That way, an A will translate as 00. No ambiguity when you use fixed widths.
Message 8 of 22
(4,333 Views)
A very good point Dennis K.  Kudos!
Message 9 of 22
(4,328 Views)
yes sir u rite that is wat i want to do but i want to treat each alphabet spreatly than it will be more accurate
Message 10 of 22
(4,327 Views)
