alphanumeric string
How to check for an alphanumeric string using Regexp function?
Message 1 of 20
(7,909 Views)
[^\d\w]
Jim
Message 2 of 20
(7,904 Views)
Thanks a lot. But the above VI fails if i give underscore or empty space so we should add condition for it i guess.
I also got it in a similar way . I am trying without using regexp , by using ASCII . Is there any way of achieving it , suppose i give a single character and it should check for alphanum.
I have also enclosed in my VI for conversion and checking for alphanum string.
Message 3 of 20
(7,895 Views)
Why do you want to avoid using regular expressions?  Unless you're using this in a loop that needs to go very fast, a regexp is fine (and much cooler).
Sorry about forgetting the underscore; how's this?  The "pipe" is an OR operator.  This regexp looks for anything that's not a word character (letters, digits and underscores) and then looks for an underscore.  If it finds either, the input string is not alphanumeric.
Jim
Message 4 of 20
(7,884 Views)
I agree with Jim about the coolness of regex.
NOTE: The pipe and underscope should be included in the character class, the correct regex is [^\w|_]
Ben64
Message 5 of 20
(7,867 Views)
That won't work.  My regexp is looking for anything that's not a word character or IS an underscore.  Yours looks for anything that's not a word character or an underscore, which is redundant and misses the underscore.
Jim
Message 6 of 20
(7,862 Views)
Sorry about that, I guess I misunderstood what is asked. I thought the OP was looking for anything that's not ( a word character or an underscore ).
Ben64
Message 7 of 20
(7,859 Views)
Remember that you can capitalize a character class for negation.
Message 8 of 20
(7,846 Views)
"Any technology sofisticated enough is indistinguishable from magic."
Regexp is magic.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 9 of 20
(7,826 Views)
of course there is the Lexical class function on the comparision palatte to do all the regexs for you!
Hmmmmm This round thing is neat--- I should call it a "Wheel"
Message 10 of 20
(7,819 Views)
