alternative low cost suppliers for LV compatible I/O cards
I'm looking for a low cost LV compatible card to use in my lab on Windows
PC's by students, because the original NI cards are not so cheap. Number of
I/O, resolution and speed is not so important, but it must work properly.I
don't want to use the "German" solution with a SoundBoard, because its quite
limited. It must have at least 4 I/O and 8 or 12 bit resolution. Has anayone
any experimence with other suppliers than National Instruments in Europe?
Thanks!
(2,947 Views)
In article <3e57dd24$0$83869$ba620e4c@news.skynet.be>, "Marc Thijs"
> Windows PC's by students, because the original NI cards are not so
> cheap. Number of I/O, resolution and speed is not so important, but it
> must work properly.I don't want to use the "German" solution with a
> SoundBoard, because its quite limited. It must have at least 4 I/O and 8
> or 12 bit resolution. Has anayone any experimence with other suppliers
> than National Instruments in Europe? Thanks!
Check out my response to this post:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000505B0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0&USEARCHCONTEXT_QUESTI
ON_0=Is+it+possible+to+acquire+an+analog+input+without+a+DAQ+board&USEARCHCONTEXT_QUESTION_S=0
Just go to MeasurementComputing.com. I've used these boards for several
years now and haven't had many problems. I would strongly suggest the
CIO-DAS08/JR for $179(US):
http://www.measurementcomputing.com/cbicatalog/cbiproduct.asp?dept%5Fid=117&pf%5Fid=183&mscssid=N1UUA2JCKE0P9PWU130KXM64XNRX1SS4
I'm sure they'll provide you an educator discount. Oh yeah, these guys
aren't in Europe so perhaps the added S/H won't make them so cheap...
Good luck,
-Kevin
(2,947 Views)
look at www.meilhaus.com ! there is a new product called labjack ! an usb measurement device with cheap costs
bye
(2,947 Views)
Thanks for the info, i will certainly investigate it next week!
Marc
"Ange" schreef in bericht
news:50650000000500000060D30000-1042324653000@exchange.ni.com...
> Hi,
> bye
(2,947 Views)
Marc
"kevin" schreef in bericht
news:Y6Y5a.9680$ep5.5638@nwrddc02.gnilink.net...
> Check o
T_QUESTION_0=Is+it+possible+to+acquire+an+analog+input+without+a+DAQ+board&U
> Good luck,
> -Kevin
(2,947 Views)
