"Control not loaded" in activeX window on Vista. nicont.dll
Hi all,
I have a problem with ActiveX and Labview on some vista machines. When I run a program with an activeX controller the text "Control not loaded" will show in the ActiveX box. It does not matter which ActiveX I try to use. The result is always the same.
The event logger in vista it says that there is a problem with nicont.dll
Ouput from event logger:
"Activation context generation failed for "C:\PROGRA~1\NATION~1\Shared\nicont.dll". Dependent Assembly Microsoft.VC80.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="8.0.50727.762" could not be found. Please use sxstrace.exe for detailed diagnosis."
The weird thing is that it works on 4 different notepads were 3 are running Vista Business and 1 are running Vista Ultimate. But when I try to install my program with the installer I made on stationary workstations running windows vista home premium and Vista Ultimate I get this problem. I suspect that the nicont.dll was not properly registred in the installation process. But it seems like I am not able to register the nicont.dll manually, even when I run it as administrator from the Administrator account.
If anyone has "been there and done that" I would be very happy if they can tell me how to solve this!
Best regards Whaler
Message 1 of 1
(2,610 Views)
