"Internal error 2902. ixoFileCopy" error when running application installer
Hello all, this is my first post to the NI Discussion Forums.
I have this LabVIEW program that I have built into an application and then packaged this application into a Windows Installer.  I've done this using the LabVIEW Build Specifications function.  When I run the resulting installer, partway through the installation I get the following error message:  "Internal error 2902. ixoFileCopy" (see attachment).
Can anyone suggest why the created installer is doing this, and what I can do about it?
I'm using LabVIEW 8.6.1.  I'm running the resulting installer on a PC running Windows XP.
Thanks in advance!
(3,192 Views)
****message deleted****
Message Edited by muks on 02-17-2010 03:09 PM
(3,180 Views)
muks, so it seems from that link that I might be able to work around the problem by limiting the CAB file size in the installer.  How can I set up the LabVIEW installer build specifications to limit CAB files to a certain size?
(3,162 Views)
