amplify a voltage and send it via cDAQ 9189
I want to generate 2 voltages continue via an analog card that makes up my acquisition and generation card set.
These 2 voltages must be generated following receipt of a value read via the modbus protocol at a defined address.
The value of the 2 voltages are relative to the value retrieved via modbus and a coefficient defined by the user. How would someone do ????
(1,178 Views)
You may need this additional library : NI Modbus Library Toolkit for LabVIEW
There is examples that are shipped with, explore them. It is possible to get work locally (localhost) a master vs. a slave, for debugging and testing purposes. You may adapt one of the examples to get your Modbus communication, and then use those values to drive your analog generation.
(1,152 Views)
