 javicur
			javicur
			01-26-2007 03:44 AM
 tbob
			tbob
			01-26-2007 10:39 AM - edited 01-26-2007 10:39 AM
Message Edited by tbob on 01-26-2007 09:40 AM
01-30-2007 08:08 AM
Thank you for reply Tbob,
With the filter I improved the sound for the case of amplitude modulation but i don't solve the problems with the frequency modulation.
I attached you the VI modified and the file i want to play (The first colon of the file is the time and the other 3 colonnes are the voltage for 3 different pressure transducers). The time acquistion is 1 second and the number of samples is 12500 but i want to play the signal in a gived time.
Thank you another time. If you do some modification or you attach me some VI could you please save it as version 8.0. I saw your VI but i asked a colegue for open it because i don't still have version 8.2.
Thank you very much
Javier
 tbob
			tbob
			01-30-2007 01:01 PM
01-31-2007 01:36 AM
Thanks Bob,
here i attached the two subVI. Thanks for your answer, it gives to me some ideas.
Javier
 tbob
			tbob
			01-31-2007 12:05 PM
02-01-2007 01:58 AM
 tbob
			tbob
			02-01-2007 05:35 PM
02-05-2007 01:23 AM
Thank you very much for your help...it was really very helpfull!!!
javi
