amplitude modulation burst
I am trying to get a Amplitude Modulated Burst by using Labview to control the Agilent 33120A. I am using the labview example Agilent 33XXX Series Generate Modulated Waveform.vi. With this I am able to generate a hanning signal. But I am looking to receive one burst instead of the continuation that I am currently receiving.
(2,560 Views)
Hi shm student,
The actual functionality of the instrument is a question more suited for Agilent to answer.  Are you able to set up this functionality using the instruments user interface?  If you know the process of setting it up on the instrument I may be able to help you mirror that process using the IVI drivers.  If not Agilent will help you determine the process and should be able to tell how to set up the IVI drivers.
Good luck!
Mike Altmann
Product R&D
NI
(2,538 Views)
