amplitude
HI   GUYS :
        I have a question about the amplitude measurement , for example , i read the waveform from the sound card ,then use
 signal anayse vi to get the RMS, amplitude, freq and so on , but  i have noticed that , the RMS or amplitude can't equals to the real world physical voltage value directlly , what can't i do? if i want to get the real voltage amplitude like a multimeter
Message Edited by adobefree@gmail.com on 11-10-2009 03:23 AM
(3,437 Views)
FFT, fast fourier transformation returns the effective value of each frequency contained in the signal. So the amplitude should compute to be a value of about 1/sqrt(2) in comparison to the actual maximum amplitude of the sinewave.
hope this helps,
Norbert
Norbert
Expert: Geometry
(3,430 Views)
Then working with sound input the data is "normalized to a full input range equal to +/- 1. So you must calibrate your data. Also remember that a sound card can not measure DC. Sound card is for AC only with a range from ca 10Hz and up
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,427 Views)
Hi:
      thanks for all your replay , it seems that sound card is not so professional , is there any other solution? i mean , i was heard about some PCI data collection card from NI , is that suitable for my requirement?  i just want to get the real peak value or amplitude of a AC signal
thanks
(3,410 Views)
